14,978 KB size limit?
scottr99
Charlotte, NC
Hello.
I am using the JavaScript code provided as an example, (https://winscp.net/eng/docs/script_download_most_recent_file) and it works PERFECT for downloading files that are a few MB's. But when I try to download a file of a larger size, say 1 GB, it stops automatically at exactly 14.978 MB. It does this for any large file, stops exactly at 14,978 KB. By the way this is for downloading analysis (computational fluid dynamics) files I am running on a remote server. I am hoping there is a simple fix for this because it seems perfect for my needs.
Any help would be very much appreciated!
Regards,
Scott R.
Reply with quote E-mail
scottr99
also..
By the way, it woks fine via the GUI. However, I can't use the GUI approach because I need to start this before I leave at night to start the download at 4AM so it's done when I arrive to work. So the GUI is not an option for me even though it works.
scottr99
SOLVED
I found that compressing and tarring the file at the remote location first, will overcome this issue (Even though the compressed & tarred file is still larger than 14,978 KB). It isn't apparent why this is so, but at this point I don't care because it now works for me.
Re: 14,978 KB size limit?
Please attach a full log file showing the problem.
