Login problem
guest
Login problem
heres a little from my log..
sent password
acess granted
opened channel for session
remote debug message: failed to launch child process!
unexpected response to shell/command: paxket type 98
(esshfatal) unexpected response to shell/command request: packet type 98
what is wrong ?????
Re: Login problem
I have no idea, I'm sorry. What server are you trying to connect to? Can you try to login with Putty SSH teminal? (use SSH!)
f-secure ssh server 5.1 build4
i cannot connect with key and putty (havent figured that out but it connects fine with username and password ..
with f-secure client everything works ...
and with winscp not at all or actually it goes to starting session ... and then 'host hasnt answered for 15 seconds ..'
Re: Login problem
This is completely different error message than one you described in previous post. Can you send me a complete log file?
Re: Login problem
ok , i read somewhere that i should edit the default shell to /bin/bash so thats the different logs when i use default this happens...
. WinSCP Version 2.1.0 (Build 119)
. Login time: den 27 januari 2003 01:21:26
. Session name: protect@192.168.1.11
. Host name: 192.168.1.11 (Port: 22)
. User name: protect (Password: Yes, Key file: No)
. SSH protocol version: 2 only; Compression: No
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes
. Ping interval: 0 sec (0 = off); Timeout: 15 sec
. SSH Bugs: A,A,A,A,A,A,A,
. Proxy: none
. Shell: default, EOL: 1
. Local directory: default, Remote directory: home, Update: No
. Clear aliases: Yes, Unset nat.vars: Yes
. Looking up host "192.168.1.11"
. Connecting to 192.168.1.11 port 22
. Server version: SSH-2.0-2.4.0 F-Secure SSH Windows NT Server
. We claim version: SSH-2.0-PuTTY-Local: Jan 12 2003 19:45:16
. Host key fingerprint is:
. ssh-dss 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx
. Initialised Blowfish client->server encryption
. Initialised Blowfish server->client encryption
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Doing startup conversation with host (shell).
. Skipping host startup message (if any).
> echo "WinSCP: this is end-of-file:0"
< Microsoft Windows 2000 [Version 5.00.2195]< (C) Copyright 1985-2000 Microsoft Corp.< . Waiting for data timed out, asking user what to do.
. Asking user:
. Host hasn't answered for 15 seconds.
. Wait for another 15 seconds? Pressing 'Abort' button will close session. ()
. Attempt to close connection due to fatal exception:
* Terminated by user.
. Closing connection.
* (ESshFatal) Error skipping startup message.
and when i use /bin/bash this happens....
. Login time: den 27 januari 2003 01:26:07
. Session name: SHELLprotect@192.168.1.11
. Proxy: none
. Shell: /bin/bash, EOL: 1
. Sent password
. Access granted
. Remote debug message: Failed to launch child process!
. Unexpected response to shell/command request: packet type 98
Re: Login problem
In first case standard Windows shell in invoked (cmd.exe), which is not compatible with WinSCP (it requires "unix" shell). I cannot say what causes problem in second case. Are you sure, that /bin/bash exists on your server?
Re: Login problem
No im not.
Im just trying to connect 2 windows machines ....i have no programming knowledge .... you say windows cmd is not compatible , what can i install inside windows to use winscp with then ? .....
Re: Login problem
Anonymous wrote:
No im not.
WinSCP requires unix-like shell. Some SSH implementation for Windows provides one. OpenSSH for Windows for example, but this project was teminated recently. Another example is Cygwin.
I have no experiences with F-secure SSH.
