No transfer log when using gui?
stpe
Hey there,
I activated the xml log for the current 4.3.9 winscp client. But there is no logging when I copy files between the local and the remote location? Only if I do stuff at the remote side it is logged. Is this by prupose, a bug or did I make a mistake in the settings?
Re: No transfer log when using gui?
There is a logging, if you upload or download files. If that's what you mean.
If it does not work for you, please provide step by step instructions for reproducing the problem.
stpe
Using WinSCP 4.3.9.1817
With GUI on windows 7 x64
1) turn on the log (doesn't matter if xml or txt)
2) connect to sftp server
3) copy file from server to local/or copy file from local to server
-> no entry in Log
4) remove file from server
-> entry in log
For me it works ok, with both logs.
