Ability to see image files
k_zeon
I use WinSCP to look at files on my Apple TV2 and some files are pictures with tbn extention.
These are just jpg image files that have had extension changed to allow XBMC to import.
Is there a way to view these files as pictures or create some form of substitue to say
read tbn files as jpb and display the pictures
tks
Re: Ability to see image files
Some viewers can detect file format, disregarding the extension. IrfanView for instance.
So if you associate the .tbn extension with such viewer, you should be able to view them.
thanks for reply, however i dont want to double click each file to see the picture if there are hundreds.
Is it possibly to create a thumbnail view within WinSCP so you can change the view mode like in windows explorer.
tks
