Overwrite
MagnusXI
Overwrite
I have my WinSCP to transfer files from 1 SFTP site to another every morning, but for some reason i cant get it to overwrite my local files on download or the second SFTP site on upload. am i missing something?
Code inclosed below: (File Names and Servers changed to generics)
option batch abort
open Server1
# Force binary mode transfer
option transfer binary
# Download file to the local directory c:\
get file1.txt c:\file\
get file2.txt c:\file\
get file3.txt c:\file\
get file4.txt c:\file\
get file5.txt c:\file\
get file6.txt c:\file\
get file7.txt c:\file\
get file8.txt c:\file\
get file9.txt c:\file\
# Disconnect
close
# Connect to a different server
open server2
# Upload the file to current working directory
put c:\file\file1.txt
put c:\file\file2.txt
put c:\file\file3.txt
put c:\file\file4.txt
put c:\file\file5.txt
put c:\file\file6.txt
put c:\file\file7.txt
put c:\file\file8.txt
put c:\file\file9.txt
# Disconnect
close
# Exit WinSCP
[/code]
Re: Overwrite
Please attach a full log file showing the problem.
