Error Code 206: The filename or extension too long
WinLinx
I have a WinSCP script which does file transfer automatically to the remote Linux machine.
I am facing Error Code: 206 saying The FileName or extension is too long.
How shall I fix it?
Re: Error Code 206: The filename or extension too long
Please attach a full log file showing the problem.
