download most recent file
deriol
Hello everyone.
I am totally new at WinScp and scripting and I am trying to automate daily download of some files.
Problem is that I only need to download most recent (i.e 1 day old file) file.
I found out that in the latest beta version of WInsCp you can put file mask with Size and Time Constraints to do that https://winscp.net/eng/docs/file_mask
However I can't manage to download only the latest excel file from the server . It keeps downloading all files.
Basically I try to do this :
winscp
open myssesion
get *.xls<1D
Thx in advance.
deriol
Re: download most recent file
Should be:
get *.xls>1D
Thank you verymuch for your swift answer.
Stupid me ! And it shouldn't have any spaces as it seems.
Thanx Verymuch !
PDGB
Put files on remote server < 1day old
Here is my script:
option batch abort
#option ignore permission
# Connect
open AvaCDX
# Upload the files
put X:\DX\Import\Bank835-test\*.*>1D /target_tx/
#Disconnect
close
# Exit WinSCP
Here is the log:
. 2013-06-20 10:46:18.467 Startup conversation with host finished.
< 2013-06-20 10:46:18.467 Script: Active session: [1] AvaCDX
> 2013-06-20 10:46:18.467 Script: put X:\DX\Import\Bank835-test\*.*>1D /target_tx/
. 2013-06-20 10:46:18.467 Copying 1 files/directories to remote directory "/target_tx/"
. 2013-06-20 10:46:18.467 PrTime: No; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2013-06-20 10:46:18.467 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2013-06-20 10:46:18.467 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2013-06-20 10:46:18.467 File: "X:\DX\Import\Bank835-test\*.*>1D"
* 2013-06-20 10:46:18.467 (EOSError) System Error. Code: 123.
* 2013-06-20 10:46:18.467 The filename, directory name, or volume label syntax is incorrect
. 2013-06-20 10:46:18.467 Asking user:
. 2013-06-20 10:46:18.467 File or folder 'X:\DX\Import\Bank835-test\*.*>1D' does not exist. ("System Error. Code: 123.
. 2013-06-20 10:46:18.467 The filename, directory name, or volume label syntax is incorrect")
* 2013-06-20 10:46:18.467 (EScpSkipFile) File or folder 'X:\DX\Import\Bank835-test\*.*>1D' does not exist.
* 2013-06-20 10:46:18.467 System Error. Code: 123.
. 2013-06-20 10:46:18.467 Script: Failed
. 2013-06-20 10:46:18.467 Script: Exit code: 1
. 2013-06-20 10:46:18.467 Closing connection.
. 2013-06-20 10:46:18.467 Sending special code: 12
. 2013-06-20 10:46:18.467 Sent EOF message
There is 1 file that is < 1 day old in that Source directory. I can copy that file manually with the GUI (no masking).
Any help would be appreciated!
Re: Put files on remote server < 1day old
PDGB wrote:
Here is my script:
What version of WinSCP are you using? Make sure you have the latest.
