Synchronize each directories
captaincoooper
Good day Martin!
Thank you once again.
I don't know if the assembly supports file synchronization. So I'm playing around with SynchronizationDirectories. But it synchronize only the target remote directory.
I'm looking for a way to synchronize each local directory to remote directory. I can walk each directories but I just want to sync the files only. Do you have any idea if this is possible.
My Objective here is to be able to track the progress of the FTP synchronization.
Unlike uploading, I can create background workers to upload each files. In this way, file uploading will be a little faster.
Thanks you.
Re: Synchronize each directories
Sorry, I do not understand. What does "I just want to sync the files only" mean that you cannot do it with Session.SynchronizeDirectories?
captaincoooper
I'm using Session.SynchronizeDirectories to synch files. But's gonna be slow because it's a single session. I want to SynchronizeDirectories using 4 Sessions. I'm thinking of synchronizing from the root directory but i want subdirectories to be excluded (using filemasking). In short i'm going to sychronize them each using 4 theads. It is it possible or do you have any alternative ideas.
thanks & regards
captaincoooper
Hi Martin - I've got this working already. Yes, the file mask do the trick. Now I got multiple backgroundworkers doing the job = faster operation. here's the piece of code below
public void Synchronize()
//this.TransferOptions.FileMask = "*.* | */";
string localpath = WebsiteFileInfo.DirInfo.FullName + @"\";
localpath = localpath.Replace(@"\\", @"\");
this.TransferOptions.FileMask = string.Format(@"{0}*.* | {1}/*/", localpath, WebsiteFileInfo.RemotePath);
SynchronizationResult synchronizationResult;
synchronizationResult = _ftpSession.SynchronizeDirectories(SynchronizationMode.Remote, WebsiteFileInfo.DirInfo.FullName, WebsiteFileInfo.RemotePath, this.DeleteObsoleteFiles, this.Mirror, this.SynchronizationCriteriaOptions, this.TransferOptions);
try
synchronizationResult.Check();
catch (System.Exception e)
this.WebsiteFileInfo.Error = string.Format("{0}", e);
_transfersCount = synchronizationResult.Uploads.Count;
_failuresCount = synchronizationResult.Failures.Count;
this.WebsiteFileInfo.Processed = true;
this.IsBusy = false;
Cheers!
:D :D :D
