special characters
Adriatika
special characters
Firstly, thanks for the great work.
A point could be very interesting to fix : special characters are not supported in files name. Very annoying in some case. Or maybe I missed something ?
Your help will be very appreciated.
Adriatika
Thanks for your answer, prikryl.
By example, I've uploaded a file named :
Film du 50ème anniversaire
In WinSCP, the file is renamed as :
Same problem with special characters such as : à é è ê and so on.
Hope it helps.
Possible trouble :
Maybe, if your computer is not compliant with these accented characters you will not able to see them as I wrote in this message.
Anonymous wrote:
Thanks a lot Martin.
I use version 4.3.9
Enabling UTF8 works!
What is your server? What protocol are you using?
