WinSCP 5.0.8 RC deleted local files on moving
MichaelMax
OS: Windows 7
I used mouse to move file from the current local directory to the up one (..). Instead of moving file it got deleted and placed under Recycle Bin.
Ricardo
Ricardo avatar
Confirmed
I can confirm this.
When dragging a file from local folder and dropping it into the "..." folder (level up), it goes to the Recycle Bin.
Also, when dragging a file from current local folder to any other local folder, default action is "create shortcut" instead of "move to folder".
Re: WinSCP 5.0.8 RC deleted local files on moving
I was not able to reproduce neither of the problems.
Can you please write me step be step in much details, what are you doing?
Re: Easy
Still no luck.
