"New and updated only" attemps to create existing folders
lhungil
Version: 5.0.8 (build 2438) and prior 5.0.7
Issue:
When attempting to copy an entire directory + contents to a remote server via FTP the error message "Copying files to remote side failed. Error creating folder ..." is encountered when the folder specified already exists.
Interestingly, WinSCP iterates over the contents of the folder, updates the contents of the folder, and then tries to create the folder.... hmmm....
Description: Example log file.
Re: "New and updated only" attemps to create existing folders
Thanks for your report. Can you please attach (or email me) a complete log file?
Zxurian
Same problem.
I just tried to do a local copy to a remote server that includes files & directories with "New or Newer only" checked.
Previously, it iterated through all directories and copied whatever needed inside directories as well as outside.
Now, it hangs if I try to copy a directory saying
Error creating folder '%folder'.
Can't create directory: File exists
Attached is a debug 2 log of when I tried to do a mass copy.
Description: log of doing copy with existing directories
lhungil
Alright, I've dug into this a little further. It appears this issue only occurs if you have "Synchronize browsing" enabled in 5.0.7+.
I am guessing there is some work to be done with "Synchronize browsing" still due to this bug with FTP and also since clicking either "Home Directory" or "Root Directory" with this setting enabled breaks the synchronization.
Zxurian
I replied to your email again (did awhile ago, but forgot to include original post link and also post here)
Let me know if you need anything else or just email me back.
Thanks!
yereverluvinunclebert
Brighton - The Beautiful South
same error message
I am running 5.10 build 2625 and I am receiving the same message. Trying to copy a newer version of a file system to remote where the file system already exists. The folders are in existence already. I merely want Winscp to ignore this and continue, it fails meaning I have to copy each and every sub-folder manually or use an alternative FTP client as a workaround.
I have FTP with TLS explicit encryption enabled. Win XP.
Please provide the patched version.
