need help on basic script
edlee
CA
Hi all i am trying to automate download every night from a sftp site
there are 3 folders i would like to download
folder1
folder2
folder3
i created a batch file
called download.bat
winscp.exe /console /command "option batch abort" "open username:password@sftp.website.com" "get folder1\* c:\download"
it runs but nothing happens what am I doing wrong
thank you all for your help
Re: need help on basic script
Is folder1 subfolder of the initial session folder?
Try using full path instead.
Also make sure you use forward slash for remote paths.
edlee
CA
Hi prikryl
folder1 is a subfolder and I just tried using forward slashes as you suggested but nothing happens
what is the difference between winscp.exe and winscp.com
