UTF-8 encoded directory name
mellerz
Since Session.CreateDirectory is not yet available, I would like to ask if there is a way to create a UTF-8 directory on the server side?
I used the session.ExecuteCommand("mkdir -p <directory name>") to create the directory however it was not UTF-8. I also added sessionOption.AddRawSettings("Utf", "1").
mellerz
Re: UTF-8 encoded directory name
With SCP protocol (what .ExecuteCommand uses), UTF8 is not supported.
Is there another way or a work around to create a UTF8 encoded directory name?
WinSCP 5.0.8 RC with Session.CreateDirectory is going live later today.
mellerz
Ok, thank you very much.
