cannot access any subfolders
Howard
When creating any directory, I always got error message "The server does not support the operation". However, the new directory would be still created after I click "Abort" or "Skip", and there was no problem to access the directories right below /<root>. However,when I tried to create subfolders, I could not access them even though I could create them with an error message like the previous one.
Here is the error message when I tried to access any subfolders:
- Error changing directory to 'New folder'
- Cannot get real path for '/New folder/New folder'
- General failure (server should provide error description).
- Error code: 4
- Error message from server: Folder not found: /New folder/New folder
- Request code: 16
It should not be a server problem because I can access it using FileZilla without any problems.
Any help is appreciated!
Howard
Re: cannot access any subfolders
Please attach a full log file (level Debug 2) showing both problems.
Ignacio
I'm having the exact same problem with WinSCP. I'm using the latest version as of today.
The same answer as above.
