keepuptoday - You will be disconnected after 15 minutes
I am using the keepuptodate command in script. It is working fine.
But I am facing a problem about the below thing
You will be disconnected after 15 minutes of inactivity
so because of the following reason, my script gets aborted after 15 mins. But my requirement is to increase that time to quite a bit or reconnects automatically how do I do that, please
Thanks!
Thanks!
