Pause/Resume File Transfer
AvidApprentice
Perhaps I am overlooking it but I cannot seem to find anything regarding pausing/resuming of file transfers. Does the .NET assembly currently have the ability to do this? If not is it on the road map?
t0r3x
Netherlands
How would you cancel a transfer you are doing with WinSCP.Session.GetFiles then? Simply a dispose (does not seem to work when I checked real quick)?
Well, again, it is not possible.
t0r3x
Netherlands
Thats to bad, is there maybe some kind of workaround for at least an abort/cancel? It is absolutely critical that I can somehow terminate a download over the SCP protocol or else my entire implementation becomes useless and my solution will sadly fall apart.
I would guess disposing the session also terminates the WinSCP.exe on the background, but when I try to do that everything just hangs, probably because the connection stays in an open state. I have also been looking at doing things manually with the ExecuteCommand method, using the scp command, but couldnt get things going with the identity file yet (Windows/Unix paths). I dont know if it will even make a difference eventually, because it will basicly be the same command I have to send that terminates the download thread.
Like I said, a big part of my program is depending on the WinSCP .NET assembly. The program I am developing uploads files via RSync and downloads via WinSCP, for storing backups on a NAS box. The RSync wrapper has not been a problem, but all now seems to come down to cancelling the download thread and disposing the session via WinSCP. I cannot have a very big file not being able to abort with a download of lets say 200 kb/s, it would kill the usability of my application. So please, if you would know anything at all that could maybe help me achieving an abort/cancel it would be greatly appreciated and would help me tremendously. Thanks a million in advance.
t0r3x
Netherlands
Disposing should help.
Please set Session.DebugLogPath, try and attach the log.
The order of events in my program is as follows. I start up a thread in the ThreadPool with session.GetFiles in it, then the thread keeps working until done downloading. When I want to cancel downloading, I do a session.Dispose on the same session object, but then it still keeps working until done with downloading. After that it does dispose, but only when done downloading. I dont quite know how to tackle this situation currently, so any tips or guidance would be greatly appreciated. To be sure I attached the log as you asked. Thanks.
Description: debug log winscp .net assembly
t0r3x
Netherlands
The more I seem to try, the more Im starting to think its a limitation in the library. Like I said earlier, when I dispose it disposes but only after having finished with GetFiles. GetFiles therefore seems uninterruptable when being executed until finished. Do you have any more information about this yet? Thanks.
