Help Using ExecuteCommand? ls is unrecognized command.
JeffLawlorEtna
United States
Greetings. Thanks for all the effort in creating this library!
I'm trying to run a "ls" command against a plain old FTP server and I get an exception:
Syntax error, command unrecognized.
Here's the code:
CommandExecutionResult result = _session.ExecuteCommand("ls");
I must be missing something simple here. Any advice?
I'm using the 5.07 beta of WinSCP and the assembly.
Thanks,
Jeff
Re: Help Using ExecuteCommand? ls is unrecognized command.
There's no "LS" FTP command.
You probably wanted to use "LIST". But that won't work anyway for numerous reasons. Primary one being that for directory listing with FTP you need to open a separate channel. The listing is not part of a direct response to the LIST command.
Anyway, what's the point? There's Session.ListDirectory command:
https://winscp.net/eng/docs/library_session_listdirectory
hendra
hello sir,
please help...
according to example in this article
https://winscp.net/eng/docs/library_session_executecommand#vbnet
i've found error after waiting some time, when execute command :
Dim strtxt As String = "mysqldump -u user -p password dbase>\test.sql"
session.ExecuteCommand(strtxt).Check()
WinSCP.SessionRemoteException : Connection has been unexpectedly closed. Server sent command exit status 0. Error skipping startup message. Your shell probably incompatible with the application (BASH is recommended).
Please start a new thread and attach a full session log file showing the problem (using the latest version of WinSCP).
