Compare directory : Wrong "No difference found"
fpabernard
Courbevoie, F92400, France
WinnSCP could be fanstastic for me, in order to obtain a NTFS image of a network drive.
But it happens that WinSCP does not see any differences on directories obviously different.
It happened for example on the "Users" folder from a drive : empty on the local drive, 5 folders on remote. The same inconstancies are found when using the "Synchronize ..." command. All files under "Users" are not found.
I fixed the problem by using another tool to copy the missing folders to the local NTFS target.
The setting is (not sure for labels, I use french version) :
  • from distant to local
  • mirror files
  • remove files
  • see changes
  • compare with file sizes only (as I have problems with I hour shift for some files, despite having checked "use DST" in the Environment tab in session dialog)
I use SFTP and the GUI to connect to the NAS (which is OpenMediaVault)
Regards,
Fred
Re: Compare directory : Wrong "No difference found"
Please attach a full log file showing the problem.
fpabernard
I have reproduced the bug on another folder : see screenshots : no differences found with the "Synchronize" command but the directory listed on each panel has different names (although similar)
Best regards
Description: Screen shot options "Synchronize"
Description: Screen shot result
Description: Log file
fpabernard
Oh, thank you !
I understand I should turn off filename modification.
However, I think I had an erroneous "No difference found" on directories without special filenames (in fact, WinSCP did not see there were missing subfolders in the target folder). If I encounter again something like this, I will complete this topic.
Best regards.
Fred
