Access violation at address 0074D41F in module 'WinSCP.exe'.
ampapa
Anyone seen this error before???
Running on a Windows 7 64 bit OS..
Just a lot of repeating errors:
* 2012-07-10 22:29:23.701 The parameter is incorrect
* 2012-07-10 22:29:23.710 (EOSError) System Error. Code: 87.
* 2012-07-10 22:29:23.710 The parameter is incorrect
* 2012-07-10 22:29:24.211 (Exception) Access violation at address 0074D41F in module 'WinSCP.exe'. Read of address 0000028C
* 2012-07-10 22:29:24.715 (Exception) Access violation at address 0074D41F in module 'WinSCP.exe'. Read of address 0000028C
* 2012-07-10 22:29:25.230 (Exception) Access violation at address 0074D41F in module 'WinSCP.exe'. Read of address 0000028C
* 2012-07-10 22:29:25.231 (EOSError) System Error. Code: 87.
* 2012-07-10 22:29:25.231 The parameter is incorrect
* 2012-07-10 22:29:25.236 (EOSError) System Error. Code: 87.
* 2012-07-10 22:29:25.236 The parameter is incorrect
* 2012-07-10 22:29:25.731 (Exception) Access violation at address 0074D41F in module 'WinSCP.exe'. Read of address 0000028C
* 2012-07-10 22:29:25.732 (EOSError) System Error. Code: 87.
* 2012-07-10 22:29:25.732 The parameter is incorrect
Re: Access violation at address 0074D41F in module 'WinSCP.exe'.
Yanki Lauer
Topic "Access violation at address 0074D41F in module 'WinSC
I am also getting this message with version 5.0.7 (build 2268) on Windows Server 2003 SP2. The error msg "System error Code 87 The parameter is incorrect" also appears.
Re: Topic "Access violation at address 0074D41F in module 'WinSC
Re: I'm having this issue as well
pwils025 wrote:
I'm using version 5.1.3 Build 2881
Is there a resolution for this?
