I cannot open many sites in WinSCP.
bparker
I like WinSCP. However, there are many websites that I cannot open or access in WinSCP. No matter what settings I use, I can't access it. There are several sites that won't open in WinSCP. However, when I use Filezilla or Smart FTP, they open fine. Clearly, my credentials are correct, but there's probably a setting that I'm using that it default that prevents these from opening. Any idea what it is? I've been refraining from using WinSCP because I can't open sites with it, but I prefer this FTP client above any other.
Thanks,
Brendan
Re: I cannot open many sites in WinSCP.
I would be great if you also attach matching log files from Filezilla.
