Nasty bug in editor goto line feature v5.0.7 beta
fred12356
There is one nasty bug that hopefully gets fixed in the next version. When I open a text file using the default editor and try goto some line number WinSCP freezes up completely and the only way to get it working is to completely shut the winscp process down in Windows task manager. This is obviously a significant inconvenience when you have several tabs and putty consoles opened and various things going on.
RobHam
Wales, UK
Internal v5.0.7 editor lock up when selecting change font
I can also confirm this go to line number bug with the internal v5.0.7 editor.
On a similar subject I found the other day another bug which will lock up the v5.0.7 editor, apologies for not posting it earlier.
1. Open the internal text editor
2. Click the preferences button on the 'text editor tool bar'
3. In the internal editor section, Click 'select font'
The editor will now be locked up, only recoverable using the task manager recovery method.
A possible fix for this - perhaps there is no need to have access to the system wide preferences button on the text editor tool bar (unless others know differently) hence suggest it be removed and the bug will be fixed.
Re: Nasty bug in editor goto line feature v5.0.7 beta
https://winscp.net/tracker/878
Note that it hangs only when you have WinSCP on secondary monitor.
Re: Internal v5.0.7 editor lock up when selecting change font
On a similar subject I found the other day another bug which will lock up the v5.0.7 editor, apologies for not posting it earlier. ...
I have sent you an email.
