SFTP connection displays all files with the same timestamp
JasonGoff
I have a problem with WinSCP (4.3.8 1771) where all files in a remote folder are displaying with the same timestamp (the timestamp of the newest file in the folder). This only happens when using SFTP.
When using FTP, the timestamps display correctly.
This is having a knock-on impact when trying to use synchronisation, as WinSCP is treating all files as new, even if they're not.
O/S: Windows 7
SFTP-4
Description: SFTP log
Re: SFTP connection displays all files with the same timestamp
I have sent you an email with a development version of WinSCP to address you have used to register on this forum.
