Error while uploading files using batch script
guptamrishabh
India
Hi All,
I am new to WinSCP scripting. I have wrtten a script which is uploading the files using a temp scipt file with the following syntax:
put -delete *.txt
But during execution of the script always last file fails to transport to the remote SFTP server. The error logs are attached.
Please help me in avoiding such errors.
Thanks in advance.
---Rishabh
Description: This is actually an xml log file being created by WinSCP itself.
guptamrishabh
India
Re: Error while uploading files using batch script
Thanks Martin,
I have tried again with the suggestion u have made in the first link and got success in the same.
But my query then would be that if this be the problem it should be for all the files. whereas some of my files got successfully transferred as evident in the logs.
Could you please elaborate on that..
Thnaks
--Rishabh
The Transfer Resume/Transfer to Temporary Filename is by default enabled only for files over 100 KiB:
https://winscp.net/eng/docs/ui_pref_resume
