using WINSCP with FTPS
shruti2885
I am trying to create an SSIS package with Execute Process task with WinSCP.
I have the following script and I am able to execute the task sucessfully but they file does not appear on the root
of my C:\ drive
option batch on
open ftp://username:password@remotesitename:portnumber
cd ******* < ---- directory on remote site where it is located
option transfer binary
get *.xls C:\
close
What am I missing?
In my execute task I have C:\Program Files (x86)\WinSCP\WinSCP.com as EXECUTABLE
and -script = C:\FTPSwinsp.txt in the arguments. When I execute the SSIS package it says searching for host...host does not exist :(
PLEASE HELP
Re: using WINSCP with FTPS
