Session closed with exit status 0
brunkhom
Hello!
I want to create a session to an ssh-Server with the following command:winscp.exe /console /command "open brunkhom:xxxxxxxx@evbprod2.ham.gdv.org"
The OS gives the information :
. 2012-06-15 13:34:21.915 Your password will expire in 28 days.
. 2012-06-15 13:34:21.915 , <no prompt>)
. 2012-06-15 13:34:21.915 Disconnected: Unable to authenticate
I can connect to the server with the GUI an I Use the Version 5.0.7. Whitout "Your password will expire in xx days." it is possible create session with commandline or Script. Is There maybe an option or something like that?
I send you the logfile as Attachment:
Thank you!
brunkhom
Description: Logfile with an older version, but the same result
Re: Session closed with exit status 0
brunkhom
Sending E-MailAdress fpr Debug-Version
Hello prikryl!
I've send you an E-Mail for sending me a Debugversion.
Thank you!
brunkom
brunkhom
Re: https://winscp.net/forum/viewtopic.php?t=11309
Hello Martin!
I've send you a couple of logfiles for the Troubleshooting.
Thanks!
brunkhom
brunkhom
Hello!
The development build works fine!
Now i can login, even if the password
expires in a few days.
brunkhom
