Suggestion: autofill "new file" filename
Gargaj
Gargaj avatar
Hungary
Just a quick idea: what if pressing Shift-F4 would automatically fill in the new file name from the file under the cursor? Total Commander does this and it greatly speeds the working process up, because often you just want to create a new version of some file you're currently working with.
Gargaj
Gargaj avatar
Hungary
It's the same idea as with files.
Let's say I have a bunch of directories that contain localization data, named "sitelanguage-en", "sitelanguage-de", "sitelanguage-fr", etc. etc. and I want to create a new one. My cursor is already over one of them so I press F7, and I only need to change the last two letters to create "sitelanguage-pl" or something.
_________________
Conspiracy ^ Ümlaüt Design
I find it bit confusing.
Note that New > Directory and New > File differ because the New > File actually behaves like Edit command, where you can manually specify name of the file to edit. Creating new file is just a side effect of typing name of non-existing file (I'm aware that this is bit confusing too). While New > Directory really just creates directory.
