Permissions
velastin
Kingston University (UK)
Permissions
I am running latest version (3-5-6 Build 213).
I connect successfully to two systems running Mandrake 9.1
When trying to set file/diretory permissions the owner and group boxes appear greyed and cannot be changed. This does not happen before. I am running from an Windows XP computer that has a Novel client installed (problem still happens even if I dont login to a Novell tree).
Any ideas?
This does not happen at home (no Novell and I might be running an earlier version of WinSCP)
_________________
Sergio Velastin
Digital Imaging Research Centre
Reply with quote E-mail
velastin
Permissions
Thanks Martin. I am connecting to the same Linux system (BTW I connect as root) now from home running WinSCP 3.3.0 Build 177 also on Windows XP Pro. This now allows me to change owner and permissions. Puzzled?
_________________
Sergio Velastin
Re: Permissions
I suppose that at home you are using SCP, while you're using SFTP on the other site. Note that SFTP is the default transfer protocol since 3.5
velastin
Permissions
Dear Martin.
Bingo! Yes. I had not realised that new version defaults to SFTP. Setting it to SCP now allows me to change owner and group. Many thanks.
_________________
Sergio Velastin
