Stuck in SysTray
adem0x
Desk
Stuck in SysTray
[WinSCP v5.0.7 beta., Win7 x64 with all the updates.]
Here is something that happened to me quite a few times, but --unfortunately-- I haven't been able to find a methodical way to reproduce it.
Sometimes, when WinSCP is minimized (with option 'Environement | Window | Minimize main window to taskbar status area (system tray)' CHECKED), it doesn't come back on.
I mean, there's no way to bring it back. It doesn't respond to clicks (single or double), nor does it have a menu that I could right-click to 'restore' WinSCP.
Odd thing is, WinSCP isn't actually frozen --when the target disconnects, it will come up with the usual reconnection dialog (only the dialog, not the main window).
As I said, I have not managed to come up with reproducible way of creating this odd behavior/bug; but, it is there.
Interestingly enough, I haven't seen such behavior in any other app --including the ones I have written ;)
I'm hoping someone else will come up with reproducible bug report.
Re: Stuck in SysTray
adem0x
Desk
Unless placebo effect applies to software, the debug version you sent me no longer suffers from this problem.
Here is a less cryptic version of the above.
The one I noticed the bug was in v5.0.7 build 2268.
The debug version you sent [v5.0.7 build 2354] doesn't have that bug anymore --I've tried it for about 5 days (24 h).
Thank you.
With 5.1.4, I am experiencing this problem, I hope it can be fixed because I need to be able to minimize and restore the application.
