Copy path to clipboard
adem0x
Desk
Currently, the context menu 'Copy path to clipboard' only works for the parent folder.
IOW, when you do a 'Copy path to clipboard', you get the path to the parent folder.
I am wondering why you don't let the same thing for items in the file pane.
I mean, it would be MUCH more useful if I could select an item (any item) and using 'Copy path to clipboard' context menu to get the full path --including the file name, if it's a file.
Could you please consider this.
Thank you
Pathduck
Pathduck avatar
Oslo
Copy to clipboard (include paths): Ctrl+Alt+C
Or for those poor mouse-bound souls: Right-click > File Names > ...
:wink:
Or maybe only in beta v5?
adem0x
Desk
Ahh.. so, that's where it is hidden..
I must say, 'File Names' is quite an obscure title for that.
IMO, it should be 'Copy to Clipboard..' instead of 'File Names' and the sub-menu labels should be:
-- File/Folder Name
-- Full Path
-- URL
and 'Insert to Command Line' is IMO superfluous: the 3 sub-menus are sufficient; I can easily handle that with 'Paste' or Ctrl+V.
Plus, it doesn't cover 'Insert Full Path into Command Line', 'Insert URL into Command Line' anyway.
