Change User after Login with 'normal' User to SU
nullpunkt
Hi all
I read this doc: https://winscp.net/eng/docs/faq_su
No Solution there works for me... I changed in this Tab to sudo -su but after
login no prompt.
It's a Linux Debian Lenny Box and in Putty it's easy to change user by this command.
What am I doing wrong and is there another possibility to get this working?
If not: Does someone knows another GUI-Client, that support this?
After a massive hack attack I really do not want to allow root to login per ssh.
Best regards
nullpunkt
Re: Change User after Login with 'normal' User to SU
