ListDirectory with file pattern
Vara04
France
How can I list on remote FTP server : /mydir/*.csv
It works fine with /mydir but not with file pattern :-\
Any solution ?
ok I can list all files and after filter them but if there is a better solution ;-)
Re: ListDirectory with file pattern
It is not supported and most protocols do not support filtering listing on the server side anyway.
So do it yourself.
Vara04
France
If I can help :
This is how it can be done :
Regexp construction pattern : see PJ
Loop on file return by ListDirectory with a new parameter pattern
RemoteDirectoryInfo v_RemoteDirectoryInfo = session.ListDirectory(path);
Regex v_Regex = FTPClientBeanCommandFTP.FindFilesPatternToRegex.Convert(pattern);
List<RemoteFileInfo> v_ListFile = new List<RemoteFileInfo>();
foreach (RemoteFileInfo v_RemoteFileInfo in v_RemoteDirectoryInfo.Files)
   if ((!v_RemoteFileInfo.IsDirectory)
      && (v_Regex.IsMatch(v_RemoteFileInfo.Name)))
      v_ListFile.Add(v_RemoteFileInfo);
// This can not be done because ".Files" is read only
v_RemoteDirectoryInfo.Files.Clear();
foreach (RemoteFileInfo v_RemoteFileInfo in v_ListFile)
   v_RemoteDirectoryInfo.Files.Add(v_RemoteFileInfo);
So it can be call like this :
RemoteDirectoryInfo v_RemoteDirectoryInfo = session.ListDirectory("/TestFTP", "*.CSV");
