Problem with symbolic links
minnoce
I use versione 3.5.6, and I'm connecting to my SFTP server (SSH.com server 3.2.9) configured with SFTP-subsystem chrooted for my user-account.
WinSCP don't create correctly symbolic links.
The major problem is that WinSCP don't permit to create relative symbolic links (those with no starting slash).
WinSCP try to insert in all cases the absolute path to the target file, and in a chrooted environment the link created in that way don't point to the right location...
This is a bug?
Thanks in advance
Re: Problem with symbolic links
Hi P!
Found another small thing concerning symbolic links: On our debian linux system a symbolic link (link2) pointing to a symbolic link (link1) pointing to a folder is displayed as a link to a file:
link2 -> link1
link1 -> folder
This may be correct though (as the second link is indeed pointing to a file, namely the other symbolic link file), but maybe there is a solution to let winscp find out what the final target of a link is...?
Thanks for answering my other post so quickly.
negg.
I have checked this, and found out that WinSCP does create link to exact path that user specifies. So it DOES not insert absolute path to link target (unless user types absolute path).
Why do you think that WinSCP does it?
link2 -> link1
link1 -> folder
It works fine for me. Is it SFTP or SCP? What version of SFTP? Please post a log file.
That's the case:
- logged and chrooted to my account (WinSCP think mi home is /)
- in the home dir (/ for the client, not fo the server) WinSCP seems to be unable to create links. Any try cause a pop-up error 'no such file or directory', even if the file/directory clearly exists!
- if I walk to a subdir, when I try to create a relative link (I think in Unix terms of ln command: "ln -s target source", WinSCP dialog seems to invert the params labels, but want them in the Unix order!!) refuse if the target file don't exists, but create the link if He thinks the target exists (WinSCP prefix with the full path the target, in my case /), and the link is created but incorrect...
Too complicated?
I not tried all cases but the bits seems to be very confusing to me!
Anonymous wrote:
That's the case:
I'm little bit confused by your email. Let's make it simpler :-)
I suppose that you still use SFTP (not SCP). What version of SFTP? On status line (bottom of the main windows) you can see something like "SFTP (v3)".
Please can you try repeat following tests that I did one my SFTP v3 server (and it was working as expected). The key shortcuts correspons to Norton-commander interface.
- create directory "somedir" (F7)
- enter the directory
- create directory "somesubdir" (F7)
- select "somesubdir" in panel (it should be selected when created)
- execute "add/edit link" command (Alt-F6). Dialog is displayed with 2nd box (point link to) prefilled with "somesubdir".
- enter "link1" to the first box (link file).
- press ok
- symbolic link "link1" is created in current directory. it has directory icon with small arrow over it.
- it is RELATIVE. it points to "somesubdir", NOT to "/.../somedir/somesubdir".
- select "somesubdir" or ".." in panel (or anything else than symlink = link1)
- execute "add/edit link" command (Alt-F6). Enter "link2" to "link file" box and "link1" to "point link to" box.
- press ok.
- symlink "link2" is created in current directory. it has directory icon with small arrow over it. And it is also RELATIVE.
In SSH terminal "ls -la" in "somedir" directory prints:
total 4
lrwxrwxrwx 1 xprim14 users 10 Mar 19 09:01 link1 -> somesubdir
lrwxrwxrwx 1 xprim14 users 5 Mar 19 09:06 link2 -> link1
drwxr-xr-x 2 xprim14 users 4096 Mar 19 08:58 somesubdir
I'm sorry... :oops:
YES, SFTP (v3), my SFTP server is a linux SSH.com 3.2.9.1
YES
YES
YES
YES
YES
- press ok
YES
NO, it is created a symbolic link "somesubdir" in the home root (/, I'm chrooted...).
Looking at symbolic link properties I see:
"Location: /
Links to: /somedir/link1"
NO, it is ABSOLUTE
Directly logged with SSH on the remote server (as superuser), I see in the SFTP account's home dir this symbolic link:
somesubdir -> /somedir/link1
It seems the server has execute the equivalent command: "ln -s /somedir/link1 somesubdir" and not the expected: "ln -s somesubdir link1"
YES
- press ok.
YES
NO, it is created a symbolic link "link1" in the home root, lookin at properties:
"Location: /
Links to: /somedir/link2"
total 4
NO, "ls -la" in the SFTP account's root dir prints:
link1 -> /somedir/link2
Sob! :cry:
"Location: /
:-( Do you have any non-chrooted account? If you do, please try to do the same with it to check it really has something to do with chrooted enviroment. It may break the SFTP implementation. Please let me know. However I'm leaving for one week now, so do not expect an anwer soon.
link2 -> link1
link1 -> folder
Sorry, my fault. Was using SCp. Now using SFTP all works fine. Should have checked this first. Thanks for the help!
negg.
minnoce
Yes, the server is under my full control :wink: .
I tried the same test logged as root (no chrooted) with same bad results :cry: .
The problem seems to be restricted to WinSCP.
Using SSH.com's SFTP command line version (tested under both Linux & Windows) there are no problems at all creating symlinks (SFTP command SYMLINK) of any type, relative or absolute, logged as chrooted or no chrooted accounts.
It seems rather restricted to SCP protocol with WinSCP. In the post before you wrote that with SFTP it works fine. Does it?
minnoce
NO. You are reading the incorrect "sub-thread"...
The messages signed by "negg" are not pertinent my problems with symbolic links (I are the user with chrooted environment problems).
minnoce
Sorry, I haven't noticed that. However I do not know how to help you. Can you create a test account on your server for me?
minnoce
Sorry... creating accounts for externals is not permitted...
If You read my last previous messages, You notice that I think this is a GENERAL problem (not only chrooted environment) beetwen WinSCP and SSH.com server.
Can You test your own SSH.com server on Unix/Linux (is freely available) trying creating symbolic links with WinSCP client?
minnoce
I do not have any unix server where I can install software. However I have downloaded evaluation version for Windows. I'll try it soon.
minnoce
Thanks for your work...
I tested WinSCP creating symbolic links on a Linux OpenSSH server and all work FINE.
The problem seems to be resctricted to SSH.com server.
minnoce
minnoce
I obtained to open for You an account on a SSH.com Linux Box (only for a limited time, a week).
Can You tell-me instructions for send confidentially to You the login information?
Minnoce
That is good news, thanks! In my forum account profile, you'll an email address.
