Tracker Bug 653
Rhialto
Donor+
Québec, QC - CANADA
Tracker Bug 653
Isn't there a checkbox to disable this? Now everytime I connect a site, it first tries to log without password and hang for 5 seconds. This is driving me crazy.
Back to 4.0.6 :-(
P.S. There is a typo in one of the message when you connect, it shows "Searching for hos..."
Re: Tracker Bug 653
Rhialto
Donor+
Québec, QC - CANADA
> 2012-05-21 09:16:15.467 USER rhialto
< 2012-05-21 09:16:15.467 331 User rhialto OK. Password required
> 2012-05-21 09:16:15.467 PASS
< 2012-05-21 09:16:20.846 530 Login authentication failed
. 2012-05-21 09:16:20.847 Connection failed.
. 2012-05-21 09:16:20.873 Password prompt (last login attempt failed)
See the 5 seconds delay? I use the portable version. I usually click a session and before 4.07 I was prompted for a password right away but now you added this :
If password is not specified on Login dialog with FTP protocol, connection is first tried without password.
so it first try without password and hang there for 5 seconds before finally prompting me to enter the password.
I think you should put it back like before and add a check box for those who want to enable logging without password. My 2 cents.
Rhialto
Donor+
I see it just have been fixed but shows 5.09. News page list 5.08 RC available so I guess 5.08 final is coming, this mean 5.09 must be a few months away. Can you send me the 5.09 beta that include that fix please?
I was just going to reply this thread to let you know I've sent you a dev version only to notice that you are asking for it. Ok, done :)
Anyway I hope 5.0.9 is coming before end of this month.
Rhialto
Donor+
Québec, QC - CANADA
wow that was fast! We happen to be online at the same time I guess...
It works GREAT!
Thank you!
