Host key wasn't verified!
sql101
USA
I am using the script tool to ftp to our secure GTP site. Could you please help me to see which part went wrong? It is complaining about the hostkey when running through SQL Analyser but no problem if I typed them manually in command prompt
I have a batch file sftp_test.bat with one line command
WinSCP.com /script=D:\sftp_test.txt
sftp_test.txt contains the following
option batch off
open username:pasword@site
Put d:\TestYYYYMMDD.txt
close
I have no problem running it by double clicking it or through the NY scheduler. But I can not run through SQL (I want to schedule as a SQL Job then with all the notification benefits)
When I run through SQL analyser
exec master.dbo.xp_cmdshell 'D:\sftp_test.bat'
here is the result I got
NULL
C:\Windows\system32>WinSCP.com /script=D:\Uploads\sftp_CAPSJob.txt
batch           off
confirm         off
Searching for host...
Connecting to host...
Authenticating...
The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is.
The server's rsa2 key fingerprint is:
ssh-rsa 2048 6d:c9:34:0e:8a:bb:3e:26:3a:75:9d:38:1a:13:11:0e
If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel.
Continue connecting and add host key to the cache?
(Y)es, (N)o, C(a)ncel, (C)opy Key: Cancel
Authentication failed.
NULL
But I want to be able to use SQL agent instead of the cmd prompt or scheduler
much thanks
tsantony
Re: Host key wasn't verified!
hi,
this is antony here, did you get the answer for your question? i'm also facing the same issue.
please help me.
regards, Antony
Please read:
https://winscp.net/eng/docs/scripting#hostkey
If that does not help, attach a full log file showing the problem (using the latest version of WinSCP).
tsantony
thanks a lot, I found the answer.
I have include the /privatekey and /hostkey, then I got the answer.
Thanks again :D
Regards, Antony
