Error: Exception: System.IO.IOException
curvetech
When I try to open a session i get the following error in my logs
[2012-05-11 13:25:19Z] [0004] Executing Assembly: WinSCP, Version=1.0.0.235, Culture=neutral, PublicKeyToken=XXXXXXXXXXXXXXX; Path: D:/XmlProcessorService/bin/WinSCP.DLL; Location: D:\XmlProcessorService\bin\WinSCP.dll; Product: 5.0.6.0
[2012-05-11 13:25:19Z] [0004] Entry Assembly: XMLProcessorService, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
[2012-05-11 13:25:19Z] [0004] Operating system: Microsoft Windows NT 5.2.3790 Service Pack 1
[2012-05-11 13:25:19Z] [0004] User: _svc_maed@XXXXXXXXXX@XXXXXXXXXX; Interactive: False
[2012-05-11 13:25:19Z] [0004] Runtime: 2.0.50727.1433
[2012-05-11 13:25:19Z] [0004] Console encoding: Input: Western European (Windows) (1252); Output: Western European (Windows) (1252)
[2012-05-11 13:25:19Z] [0004] Session.Open entering
[2012-05-11 13:25:28Z] [0004] Exception: System.IO.IOException: The file exists.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.__Error.WinIOError()
at System.IO.Path.GetTempFileName()
at WinSCP.Session.Open(SessionOptions sessionOptions)
[2012-05-11 13:25:28Z] [0004] Session.Cleanup entering
[2012-05-11 13:25:28Z] [0004] Session.Cleanup leaving
[2012-05-11 13:25:28Z] [0004] Session.Open leaving
[2012-05-11 13:25:28Z] [0004] Session.Open entering
[2012-05-11 13:25:37Z] [0004] Exception: System.IO.IOException: The file exists.
[2012-05-11 13:25:37Z] [0004] Session.Cleanup entering
[2012-05-11 13:25:37Z] [0004] Session.Cleanup leaving
[2012-05-11 13:25:37Z] [0004] Session.Open leaving
[2012-05-11 13:25:37Z] [0004] Session.PutFiles entering
[2012-05-11 13:25:37Z] [0004] Session.PutFiles leaving
[2012-05-11 13:25:37Z] [0004] Session.Dispose entering
I've noticed that it is in consistent in that the same code will produce different results depending on the computer is is being run from. On my machine I have no problem establishing a connection to the remote server. When I run my code from my production server I get the above error. Any help would be greatly appreciated.
I am doing this using the SFTP protocol and the Win SCP .Net assembly version 5.0.6.
Re: Error: Exception: System.IO.IOException
5.0.6 failed to remove the temporary files from Temp folder. So you may have run out of temp files sequence number (having 65535 temp files already). Please check your temp folder and upgrade to 5.0.7, which cleans the temp files properly:
https://winscp.net/tracker/849
curvetech
We have upgraded to 5.0.7 and are still running into this issue. I've looked into the c:\windows\temp folder and I don't see any *.tmp files that need to be cleared out. I'm running this as a windows service and I've checked the permissions that the service is running under and it has read and write permissions to the folder.
Please check folder where %TEMP% points to. Should be like C:\Users\username\AppData\Local\Temp, but may vary depending on version of Windows.
gunnerit
Ha Noi - Viet Nam
Still error
I have upgrade to 5.0.7 and deleted all temp file in %TEMP% .
But it's still error.
Please help me.
