custom profiles for all users from silent install
GHITSupport
Thanks in advance for any help you can provide.
I am trying to create a custom installer to roll out to multiple users that will incorporate two predefined FTP sites. I have modified the iss file and rebuilt the installer which works if the user is logged on as it creates the registry keys for the current user.
we will roll out the installer while the users are not logged in and therefore no current user registry.
where should I put the predefined FTP profiles so that all users see the profiles when they launch winscp?
winscp version 4.3.7.0
Re: custom profiles for all users from silent install
There are no pre-defined profiles in WinSCP. Profiles have to be in HKCU or in an INI file.
