TMP files are not being cleaned up after Session is closed
gschmidt34
United States
Every time a Session is opened a .tmp file is created in the c:\windows\temp directory, but these files are not getting removed when the Session is destroyed - even if explicitly called Session.dispose();
Is there an option for this? Or how should it be handled?
ted1001
gschmidt34 wrote:
I downloaded the latest release and the issue appears to be resolved.
I just downloaded the latest version.
tmp-files are not deleted after running dispose.
Winscp.exe 5.0.7.2268
Winscp.dll 5.0.7.0 (file version 1.0.0.528)
Reply with quote E-mail
Old ones or new ones? The olds one are not. You need to delete them manually. But the new ones should be deleted.
ted1001
The new ones are not deleted. Triggering it from Powershell like this:
$sessionOptions.HostName = "---------REMOVED--------"
$sessionOptions.UserName = "---------REMOVED--------"
$sessionOptions.Password = "---------REMOVED--------"
$sessionOptions.SshHostKey = "ssh-rsa 1024 ---------REMOVED--------"
$session.ExecutablePath = $winscpPath
$session.DisableVersionCheck = "true"
Example of the content of a tmp-file not deleted:
<?xml version="1.0" encoding="UTF-8"?>
<session xmlns="https://winscp.net/schema/session/1.0" name="---------REMOVED--------" start="2012-05-24T08:22:55.320Z">
<group name="open -hostkey=&quot;ssh-rsa 1024 ---------REMOVED--------&quot; -timeout=15 &quot;sftp://---------REMOVED--------5&quot;" start="2012-05-24T08:22:55.711Z">
</group>
<group name="stat -- &quot;./files/lmsdeploy/---------REMOVED--------/uploadcompleted.true&quot;" start="2012-05-24T08:22:55.758Z">
<stat>
<filename value="/files/lmsdeploy/Atlantic/uploadcompleted.true" />
<result success="false">
<message>Can't get attributes of file './files/lmsdeploy/Atlantic/uploadcompleted.true'.</message>
<message>No such file or directory.
Error code: 2
Error message from server: No such file
Request code: 7</message>
</result>
</stat>
<failure>
<message>Can't get attributes of file './files/lmsdeploy/---------REMOVED--------/uploadcompleted.true'.</message>
Error code: 2
</failure>
</group>
<group name="exit" start="2012-05-24T08:22:55.883Z">
</group>
</session>
I will contact you shortly.
I have sent you an email with a development version of WinSCP to address you have used to register on this forum.
gunnerit
Ha Noi - Viet Nam
So that how to resoled this problem. I also have this issue.
I create a service run on Win2k8 Server.
zaus
Still not cleaning up...
Only for me, these are in the application directory (same folder as the WinSCP.dll/exe).
Where do these come from?
I'm using the Nuget package (product version 5.7.6, file version 1.2.10.5874)
Re: Still not cleaning up...
Which "these"? Please start a new thread and describe your problem in details, including a debug log (Session.DebugLogPath).
Naresh
Re: TMP files are not being cleaned up after Session is closed
[quote="Naresh"]
Thanks for your post.
https://winscp.net/tracker/849
Hi Team,
I am also using Winscp to poll the files remotely.
I am also facing same issue [ TMP files are not being cleaned up after Session is closed ] .
Is there any solution to delete temp files.
We need to now a way more to help you.
How are you using WinSCP? Show us some code. Show us log files. What TMP files specifically?
