Login window hiding beneath the main windows make it unusabe
transisto
Login window hiding beneath the main windows make it unusabe, unable to close / resize window.
I'm not using WinSCP very often, I'd say it happened to me ~15 time, in which case I had to kill the process.
Windows 7
Re: Login window hiding beneath the main windows make it unusabe
What version of WinSCP are you using? Have you tried the 5.0.7 beta?
