Different way to use WinSCP within SSIS using a Script task
pturner
Must have WinSCP installed
  • Run gacutil -i "C:\Program Files\WinSCP\WinSCP.dll" within the command prompt, as an admin
  • Within your SSIS Script task, add a reference to the dll file using the browse task
  • add using WinSCP;
  • your Main() method can now look similar like the following:
public void Main()
    string strFTPPath = Dts.Variables["FTPFolderPath"].Value.ToString();
    string strDestination = Dts.Variables["DestinationFolder"].Value.ToString();
    bool fireAgain = false;
    strFTPPath = strFTPPath + @"/";
    Dts.Events.FireInformation(0, "FTP Path Used:", strFTPPath, "", 0, ref fireAgain);
    Dts.Events.FireInformation(0, "Destination Path Used:", strDestination, "", 0, ref fireAgain);
    try
        // Setup session options
            Protocol = Protocol.Sftp,
            HostName = "FTP server",
            UserName = "User",
            Password = "Password",
            SshHostKey = "ssh-rsa xxxx xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
            // Connect
            session.ExecutablePath = @"C:\Program Files\WinSCP\WinSCP.exe";
            session.Open(sessionOptions);
            // Upload files
            transferOptions.TransferMode = TransferMode.Binary;
            TransferOperationResult transferResult;
            //transferResult = session.PutFiles(@"d:\toupload\*", "/home/user/", false, transferOptions);
            transferResult = session.GetFiles(strFTPPath, strDestination, false, null);
            // Throw on any error
            transferResult.Check();
            // Print results to output box
            foreach (TransferEventArgs transfer in transferResult.Transfers)
                Dts.Events.FireInformation(0, "Files Uploaded:", "", "", 0, ref fireAgain);
            session.Dispose();
        //return 0;
    catch (Exception e)
        Dts.Events.FireInformation(0, "Error: ", e.Message.ToString(), "", 0, ref fireAgain);
        Dts.TaskResult = (int)ScriptResults.Failure;
        //return 1;
    Dts.TaskResult = (int)ScriptResults.Success;
LOHITH NR
Please help me how to script task for loading file to winScp
Details
string WinSCPExePath = @"C:\Users\lohith.rajachar\AppData\Local\Programs\WinSCP";
string SFTPUserName = "abc";
string SFTPPassword = "abc";
string SFTPHostname = "111111";
string fileToUpload = @"\Allergan_DataBase_Dump";
string SFTPTargetPath = "Flat File Connection Manager";
string SFTPsshKey = "ssh-rsa 2047....";
