Using .Net to rename file
mikedovell
USA
I am having an issue renaming the files that I transfer. The exact error that I receive is "Element "call" not found in the log file.
I am calling session.executecommand(mv fileuploaded newfilename);
Any help would be much apprecitated.
Re: Using .Net to rename file
I was not able to reproduce the problem. For me session.ExecuteCommand("mv ... ...") works.
Vara04
France
Same pb:
I've got
'MV': command not understood.
I try with mv, MV, rename with the same result
2012-05-26 11:46:18Z] [0001] CallstackAndLock..ctor entering
[2012-05-26 11:46:18Z] [0001]   Command: [call MV /TestFTP/AACC.CSV /TestFTP/OUT/AACC.CSV]
[2012-05-26 11:46:18Z] [0001]   ExeSessionProcess.ExecuteCommand entering
[2012-05-26 11:46:18Z] [0003]       Scheduling output: [winscp> call MV /TestFTP/AACC.CSV /TestFTP/OUT/AACC.CSV]
[2012-05-26 11:46:18Z] [0003]     ExeSessionProcess.ProcessInputEvent leaving
[2012-05-26 11:46:18Z] [0003]   ExeSessionProcess.ProcessEvent leaving
[2012-05-26 11:46:18Z] [0001]   ExeSessionProcess.ExecuteCommand leaving
[2012-05-26 11:46:18Z] [0001]   Output: [winscp> call MV /TestFTP/AACC.CSV /TestFTP/OUT/AACC.CSV]
[2012-05-26 11:46:18Z] [0003]   ExeSessionProcess.ProcessEvent entering
[2012-05-26 11:46:18Z] [0003]     Scheduling output: [500 'MV': command not understood.]
[2012-05-26 11:46:18Z] [0001]   Output: [500 'MV': command not understood.]
[2012-05-26 11:46:18Z] [0003]     Scheduling output: ['MV': command not understood.]
[2012-05-26 11:46:18Z] [0001]   Output: ['MV': command not understood.]
[2012-05-26 11:46:18Z] [0003]     Scheduling output: []
[2012-05-26 11:46:18Z] [0001]   Output: []
[2012-05-26 11:46:18Z] [0003]     ExeSessionProcess.ProcessInputEvent entering
[2012-05-26 11:46:18Z] [0001]   Exception: WinSCP.SessionRemoteException: 'MV': command not understood.
[2012-05-26 11:46:18Z] [0001]   Failed: [WinSCP.SessionRemoteException: 'MV': command not understood.]
[2012-05-26 11:46:18Z] [0001] CallstackAndLock..ctor leaving
Any idea ?
Vara04 wrote:
Same pb:
I've got
With FTP protocol this should do:
session.ExecuteCommand("RNFR ...")
session.ExecuteCommand("RNTO ...")
Though I cannot test it atm.
mikedovell
USA
Please set Session.DebugLogPath and post the log.
I get an error that access to the path is denied and I am local admin on this machine. I have tried multiple paths with the same result.
Can you be more specific please? Like posting the exception, including callstack. Also, how do you run the .NET code?
mikedovell
USA
session.SessionLogPath = "C:\logs" - Throws the exception "141"
session.SessionDebugPath = "C:\logs" - Throws the exception "Access to the path 'C:\logs' is denied."
It doesn't mater which directory that I point those two properties to, I always get those two exceptions. If I use the path ending with a backslash Eg - C:\Logs\ I get an exception that the property is not in the correct format.
Thanks,
Mike
It should be path to file (e.g. "c:\logs\session.log"), not path to directory.
mikedovell
USA
Here is the debug log from the Call to rename the file. What's strange from the output is that when I just upload a file to the server it uses my public key and once I rename the public key section is empty. Perhaps this is why the server is refusing the command to rename?
[2012-06-04 09:55:07Z] [000a] Scheduling output: [winscp> call rename /incoming/sftptestfile3.tmp /incoming/sftptestfile3.txt]
[2012-06-04 09:55:07Z] [000a] ExeSessionProcess.ProcessInputEvent leaving
[2012-06-04 09:55:07Z] [000a] ExeSessionProcess.ProcessEvent leaving
[2012-06-04 09:55:07Z] [000a] ExeSessionProcess.ProcessEvent entering
[2012-06-04 09:55:07Z] [000a] Scheduling output: [Searching for host...]
[2012-06-04 09:55:07Z] [0009] Output: [winscp> call rename /incoming/sftptestfile3.tmp /incoming/sftptestfile3.txt]
[2012-06-04 09:55:07Z] [0009] Output: [Searching for host...]
[2012-06-04 09:55:07Z] [000a] Scheduling output: [Connecting to host...]
[2012-06-04 09:55:07Z] [0009] Output: [Connecting to host...]
[2012-06-04 09:55:08Z] [000a] ExeSessionProcess.ProcessEvent entering
[2012-06-04 09:55:08Z] [000a] Scheduling output: [Authenticating...]
[2012-06-04 09:55:08Z] [0009] Output: [Authenticating...]
[2012-06-04 09:55:08Z] [000a] ExeSessionProcess.ProcessEvent leaving
[2012-06-04 09:55:08Z] [000a] Scheduling output: [Using username "REMOVED".]
[2012-06-04 09:55:08Z] [0009] Output: [Using username "REMOVED".]
[2012-06-04 09:55:09Z] [000a] ExeSessionProcess.ProcessEvent entering
[2012-06-04 09:55:09Z] [000a] Scheduling output: [Authenticating with public key "".]
[2012-06-04 09:55:09Z] [0009] Output: [Authenticating with public key "".]
[2012-06-04 09:55:09Z] [000a] ExeSessionProcess.ProcessEvent leaving
[2012-06-04 09:55:09Z] [000a] Scheduling output: [Server refused to start a shell/command]
[2012-06-04 09:55:09Z] [0009] Output: [Server refused to start a shell/command]
[2012-06-04 09:55:09Z] [000a] Scheduling output: [Authentication log (see session log for details):]
[2012-06-04 09:55:09Z] [000a] Scheduling output: [Using username "REMOVED".]
[2012-06-04 09:55:09Z] [0009] Output: [Authentication log (see session log for details):]
[2012-06-04 09:55:09Z] [0009] Output: [Using username "REMOVED".]
[2012-06-04 09:55:09Z] [000a] Scheduling output: [Authentication failed.]
[2012-06-04 09:55:09Z] [0009] Output: [Authentication failed.]
[2012-06-04 09:55:09Z] [000a] ExeSessionProcess.ProcessInputEvent entering
[2012-06-04 09:55:09Z] [0009] Exception: WinSCP.SessionLocalException: Element "call" not found in the log file
[2012-06-04 09:55:09Z] [0009] CallstackAndLock..ctor leaving
[2012-06-04 09:55:09Z] [0009] CallstackAndLock..ctor entering
[2012-06-04 09:55:09Z] [0009] Session.DoDispose entering
[2012-06-04 09:55:09Z] [0009] Session.Cleanup entering
[2012-06-04 09:55:09Z] [0009] Command: [exit]
[2012-06-04 09:55:09Z] [0009] ExeSessionProcess.ExecuteCommand entering
[2012-06-04 09:55:09Z] [0009] ExeSessionProcess.ExecuteCommand leaving
[2012-06-04 09:55:09Z] [000a] Scheduling output: [winscp> exit]
[2012-06-04 09:55:09Z] [000a] ExeSessionProcess.ProcessInputEvent leaving
[2012-06-04 09:55:09Z] [0009] ExeSessionProcess.Close entering
[2012-06-04 09:55:09Z] [0009] ExeSessionProcess.Close leaving
[2012-06-04 09:55:09Z] [0009] ExeSessionProcess.Dispose entering
[2012-06-04 09:55:09Z] [000a] ExeSessionProcess.ProcessEvents leaving
[2012-06-04 09:55:09Z] [0009] ExeSessionProcess.Dispose leaving
[2012-06-04 09:55:09Z] [0009] Session.Cleanup leaving
There's no date set yet.
Anyway, please set Session.SessonLogPath and post or email me the log. I want to investigate why the key is empty when renaming the file.
