Execute WinSCP from a batch file
Quickdeveloper
Hi
I want to execute winscp script from a batch file.
Assume the following contents are in C:\MYFILE.BAT
echo " OPENING THE SESSION "
winscp.com /console /command:"open xyz:abc@ipaddress"
echo "CONNECTED TO THE VM "
REM   delete old files
rm file1.tar
when I run C:\>MYFILE.BAT, I am able to connect to unix vm, however it goes into shell mode and second command (deleting file1.tar won't get executed). do we need to give any other parameter?
I know we can execute batchfile itself from winscp directory (eg: winscp.com /script:filename.bat) but in that case i can't check errors with if/ else conditions in batch file since winscp doesn't recognise the if/else.
Any suggestions please? i don't want to use xml logging as it looks too complicated for my use.
quickdeveloper
WinSCP from batch file
Please also note that i am using winscp.com to redirect the output to a text file.
The only other option would be to open a new winscp session in each command line of batch file which involves more cost.
quickdeveloper
Thanks Martin,i checked it.
I have used C# with WinSCP dll and accomplished the task.
I realized it's much easier and faster that way in terms of exception handling :D
Thanks!
atchere
Re: Execute WinSCP from a batch file
Question I am having trouble getting WINSCP to take a password in the batch mode what is the correct syntex to make this happen
atc
Prasadhello
Winscp from bat file
I am trying to run winscp from bat file and with xp_cmdshell in sql server. However when I run it keeps running forever. I have put exit in bat file. Anybody aware of this issue?
Also is there any way to capture winscp dir results in sql server table or like normal result set instead of XML.
Re: Winscp from bat file
Please start a new thread and attach a full log file showing the problem (using the latest version of WinSCP).
Mahmoud
send file to sftp server
Hi all,
I did the following batch file to send file to sftp server, but the put command (or any commands) after sftp session opeded didn't work:
cd C:\Program Files\prog1\output1
WinSCP.exe username@x.x.x.x/example/test
put %file%
close
can any one help?
thanks
Fairfielder
Re: send file to sftp server
I don't understand. On the following page it shows this example batch file, which combines WinSCP and Windows commands:
https://winscp.net/eng/docs/guide_automation
Here's the example batch file:
winscp.com /script=example.txt
if %ERRORLEVEL% neq 0 goto error
echo Success
sendmail.exe -t < success_mail.txt
exit 0
:error
echo Error!
sendmail.exe -t < error_mail.txt
exit 1
Madhu
Scripting Public key authentication passphrase
Hi
I am trying to get file using SFTP. My set up was authentication with public key Passphrase.
Here is my script file name getfile.txt
open xxxxxx (site already stored with host name, port and username)
passphrase
get *.txt to c:\*.txt
Close
Created download.bat file as follows:
@echo off
winscp.com /script=getfile.txt
both the files are saved at WinSCP folder.
When download.bat file run, the script did not take Passphrase as per second line and come out without further execution.
Can anyone help how input Passphrase.
Madhu
Did you ever resolve this issue? I am experiencing the same issue - no log files to give me a hint at the problem.
How did you resolve this issue??
What did you try to get the logs?
Nothing was in the logs. My xp_cmdshell query just runs...the same issue you reported experiencing.
I'm sorry, but I do not understand your response.
I have asked: What did you try to get the logs?
optimus
Thanks!
can u share the code
