how to disable "lookup user groups" via command line
bkerez
i know it's been asked before but i got no answer.
is there a way to run the following without failing on the errors:
C:\Program Files\WinSCP>winscp.com scp://root:mypassword@HostIP:22 /script=c:\myscript.txt
Automatic actions are disabled when URL address is provided on command-line.
Searching for host...
Connecting to host...
Authenticating...
Using username "root".
Authenticated.
Starting the session...
Reading remote directory...
Command 'pwd'
failed with return code 0 and error message
: groups: not found.
Session started.
Active session: [1] root@HostIP
winscp>
Re: how to disable "lookup user groups" via command line
Please read FAQ
https://winscp.net/eng/docs/faq_script_ini
Though I do not think your problem is related to ": groups: not found.". It's more likely releated to: "Automatic actions are disabled when URL address is provided on command-line."
Instead of "scp://root:mypassword@HostIP:22" on command line, you should do "open scp://root:mypassword@HostIP:22" from your script file.
