how can i get the SShKey from server ?
deconett
halo,
i have a big problem :),namely, I write a C # program that scans a network and connect using WinSCP to several servers.to connect to this server, I need a SSHkey!!!
how can i get this SShKey from server ?
can i connect to the Server without SSH key?
Many thanks for your help
Re: how can i get the SShKey from server ?
You should know it before connecting. Should be part of the info you get from the server admin, along with your credentials.
deconett wrote:
there exists a function with which I can get this infos from the server ? like winSCP does that.
No. That would spoil the purpose of key verification.
when are the update with the event to implement custom way of verifying the host key coming? :)
I cannot give any date yet.
Perhogan
Germany
I had the same problem today and I solved this way:
Assuming that i trust that the server that is at the address is reliable (it is an internal server in the network)
1) I purged the data saved in WinSCP from previous connections so it erases the saved key (under tools).
2) i reconnected to the sftp server, biung the 1st time WinSCP shows me the key and ask if I accept it anyway
3) At this point you see a message with the Key and there is a button to copy it :-)
problem solved :-)
You can also get the key on Server and Protocol Information Dialog:
https://winscp.net/eng/docs/ui_fsinfo
