automation downloading and uploading more recent file
Mahdi Bashiri
Dear
i'm using winscp script to downloading more recent file from remote ftp server to localdirectory and uploading more recent file from localdirectory to remote ftp server and want to use these scripts to keep up to date by using :
synchronize local D:\IscFtp\Report Report for downloading
synchronize remote D:\IscFtp\In In for uploading
i would like to know is there ant script to do keep up to date remote or local directory like in gui option or no. and use this script to running all time and monitoring and changes and do downloading or uploading.
Regards,
Mahdi Bashiri
Jovy
Upload recent file from local server to the remote server
I've tried the "-latest" command and it works fine although I need to upload files with a time duration (i.e. 24 hours). I've read that I could use "-filemask" but when I am executing .bat file, the script simply doesn't proceed. The cmd shows and closes immediately. Please help.
Script:
open sftp://sftpJSamar:username@host_ip/ -hostkey=""
lcd C:\Users\Jovy.Samar\Desktop
cd /home/ftp-files/SAC/MASTERS
put -filemask="*>=1D" C:\Users\Jovy.Samar\Desktop\* /home/ftp-files/SAC/MASTERS
Batch file:
@echo on
/log="C:\Users\Jovy.Samar\Desktop\log\WinSCP.log" /ini=nul ^
/command ^
"open sftp://sftpJSamar:username@host_ip/ -hostkey=""""" ^
"lcd C:\Users\Jovy.Samar\Desktop" ^
"cd /home/ftp-files/SAC/MASTERS" ^
"put -filemask="*>=1D" C:\Users\Jovy.Samar\Desktop\* /home/ftp-files/SAC/MASTERS" ^
"exit"
if %WINSCP_RESULT% equ 0 (
echo Success
) else (
echo Error
exit /b %WINSCP_RESULT%
Re: Upload recent file from local server to the remote server
So do you run the script or the batch file?
Your batch file has quotes wrong.
See
https://winscp.net/eng/docs/commandline#syntax
https://winscp.net/eng/docs/faq_batch_file#quotes
