scp/sftp-url-bugs
Zoyo
scp/sftp-url-bugs
Hi.
I've got some problems with this new URLs.
1. If the URL contains a whitespace then winscp can't open the directory. It breakes the pathname at this whitespace.
2. It seems that I can't use URLs pointing to files. winscp tries to do a cd to that URL. This gives an error like: "-bash: cs /home/foo/bla.pdf: Not a directory." with the URL scp://server/home/foo/bla.pdf
I think that the application linked to the filetype should start like it does when klicking on a file manually.
regards,
Zoyo
nils
Re: scp/sftp-url-bugs
I can confirm the both problems. I'll try to do something with it.
these problems still exists in 3.7.0 Build 254.
Any hints?
Thanks,
Nils
Any hints?
The second problem is AFAIK resolved. If you use URL http://server/path/file the file will be downloaded. but now I have maybe noticed small problem. The path cannot be relative to home directory, it must be full path.
The first problem maybe still exists, but I'm not able to reproduce it. Can you tell me what exactly are you doing and on what version of Windows, with what browser?
Windows XP professional + IE 6 SP2 fully patched + Mozilla 1.7.3
ok second problem is solved, but only if there is no whitespace. I tried to replace whitespaces in the url with %20 or '+' (sftp://foo.bar.com/file%20blubb.txt). It gives me a "Invalid access to memory" error.
I can't confirm the relativ path issue!
Now to the first problem:
i.e. url: "sftp://foo.bar.com/dir with whitepace" error msg : File or folder 'dir' does not exists.... as expected.
i.e. url: "sftp://foo.bar.com/dir%20with%20whitepace" error msg : invalid access to memory
thanks,
Nils
Change SFTP/SCP handler as follows (in windows registry)
REGEDIT4
[HKEY_CLASSES_ROOT\SFTP\shell\open\command]
@="\"path_to_install_dir\\WinSCP3.exe\" \"%1\""
REGEDIT4
[HKEY_CLASSES_ROOT\SCP\shell\open\command]
Note the added quotes around %1.
This way it works with IE the both ways (with space and with %20). IE replaces user-entered space for %20 automatically. But before it passes the URL to WinSCP it replaces %20 with space back.
Mozilla does not perform the replacement in either way. So with it the syntax with %20 will not work.
I'll add support for %XX to next version.
