Copy url to clipboard - missing password
fsmc
Dear Support,
I'm using Winscp 4.3.7 but had the same problem with version 5.0.6. After opening a stored ftp session and using "File Names -> Copy URL to Clipboard" the password is missing and looks like in this example:
ftp://username@ftp.server.com/file.zip
This shows up on both operating systems, win7(x86) and windows server 2008. I did not find any informations in the faq or the program options to fix this. Hope you can help.
Thanks in advance
Florian
Re: Copy url to clipboard - missing password
Thanks for your post. We will consider improving this.
Actualy, what do you want to do with the URL?
fsmc
We want to send the URL with email, including username/password.
