cannot login
hermal4
cannot login
when i login into shell.sourceforge.net it says
access denied.
too many failures for hemal4
with same username/password i can login to sourceforge
can any one help..
thanks
Re: cannot login
Please, post a log file.
this is the log file
. WinSCP Version 3.5.6 (Build 213)
. Login time: Monday, March 15, 2004 3:28:02 PM
. Session name: hemal4@shell.sourceforge.net
. Host name: shell.sourceforge.net (Port: 22)
. User name: hemal4 (Password: Yes, Key file: No)
. Transfer Protocol: SFTP (SCP)
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs:
. Proxy: none
. Shell: default, EOL: 0
. Local directory: default, Remote directory: home, Update: No, Cache: Yes
. Cache directory changes: Yes, Permanent: Yes
. Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. Looking up host "shell.sourceforge.net"
. Connecting to 66.35.250.208 port 22
. Server version: SSH-1.99-OpenSSH_3.5p1
. We claim version: SSH-2.0-WinSCP-release-3.5.6
. Host key fingerprint is:
. ssh-dss 1024 4c:68:03:d4:5c:58:a6:1d:9d:17:13:24:14:48:ba:99
! Using username "hemal4".
. Keyboard-interactive authentication refused
. Session password prompt (hemal4@shell.sourceforge.net's password: )
. Using stored password.
. Sent password
! Access denied
. Access denied
. Asking user for password.
. Sent password
! Access denied
. Access denied
. Received disconnect message (SSH_DISCONNECT_PROTOCOL_ERROR)
. Disconnection message text: Too many authentication failures for hemal4
. Server sent disconnect message
. type 2 (SSH_DISCONNECT_PROTOCOL_ERROR):
. "Too many authentication failures for hemal4"
* (ESshFatal) Authentication failed.
* Authentication log (see session log for details):
* Using username "hemal4".
* Access denied
* Access denied
* Server sent disconnect message
* type 2 (SSH_DISCONNECT_PROTOCOL_ERROR):
* "Too many authentication failures for hemal4"
Re: cannot login
Hmm, I cannot see anything wrong in the log. I'm sorry, I have not clue for you. I can connect to shell.sourceforge.net without problem.
Can you try to login using Putty SSH client?
