Limit Synchronize directory recursion to one level
Guest_20120410
Is there a way to limit synchronize recursion to one level? For example, using a filemask of A*/ would synch all subdirectories and their subdirectories matching the pattern, can it be limited to just one level deep?
Re: Limit Synchronize directory recursion to one level
You would have to explicitly exclude all second-level subdirectories.
