WinSCP not prompting for new Password
christian.sandrini@...
Hi
As per this website (https://winscp.net/eng/docs/ui_authenticate#password_change) it says that it should prompt for a new password when the account has been disabled. Somehow it does not work on my system:
I have disabled an account on the sftp server
When trying to login via SSH it prompts for a new password
WARNING: Your password has expired.
You must change your password now and login again!
Changing password for user ex2m3.
Changing password for ex2m3.
(current) UNIX password:
But in WinSCP i just get the error
Cannot initialize SFTP protocol. Is the host running a SFTP server?
Any ideas how I can fix that?
Re: WinSCP not prompting for new Password
No, it says that WinSCP supports password change request initiated by the server. So your server probably does not support this.
christiansandrini
How can I configure the server to support it then? I use openssl-1.0.0-20
To add on this. The server is requesting for a new password. See first post. But it only works using SSH. Not over WinSCP
chrissandrini
I meant openssh (openssh-5.3)
chrisSandrini
Nevermind. I found the solution. Maybe you can add it to your Documentation
I use openssh 5.3
change the following in sshd_config
UsePAM yes
ChallengeResponseAuthentication yes
PasswordAuthentication no
This will work
