Error message on log file
c10c
New Delhi
2012-04-05 10:07:18 INFO Connectoin to sFTP succeeded
2012-04-05 10:07:18 INFO ------Async Upload through WINSCP starts-------
2012-04-05 10:07:18 FATAL Error while uploading data to Akamai: Cannot access a closed file.
2012-04-05 10:07:19 FATAL Error while uploading data to Akamai: Error parsing session log file
[2012-04-05 10:12:49Z] [000d] Exception: WinSCP.SessionLocalException: Element "group" not found in the log file
[2012-04-05 10:12:49Z] [000b] Exception: WinSCP.SessionLocalException: Error parsing session log file ---> System.Xml.XmlException: Unexpected end of file has occurred. The following elements are not closed: group, session. Line 6, position 1.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.ThrowUnclosedElements()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at WinSCP.SessionLogReader.DoRead()
--- End of inner exception stack trace ---
[2012-04-05 10:12:49Z] [000d] Session.PutFiles leaving
[2012-04-05 10:12:49Z] [000b] Session.PutFiles leaving
[2012-04-05 10:12:49Z] [0009] Session.PutFiles leaving
Any idea on why does this error happen? I am trying to upload simultaneous files using delegates..
Please help
Reply with quote E-mail
c10c
New Delhi
change
Hi
The implementation was changed and I have now separate session objects being created for each upload
Now, for example If I have 36 files to upload, it processes like 18-20 of them and for the rest, throws the following error -
2012-04-06 14:02:26 FATAL Connected to sFTP failed: Connection has been unexpectedly closed. Server sent command exit status 0.
Can you help me by explaining for status 0 here is?
-Chirag
Re: full log
c10c wrote:
Thanks for responding - the full log is attached
Ok, please check server log file to see, why it forcibly closes your session.
c10c
New Delhi
question
The differences between a successful session and unsuccessful are mentioned below -
Successful -
! 2012-04-09 13:57:42.387 Authenticating with public key "rsa-key-20120217"
. 2012-04-09 13:57:42.409 Sent public key signature
. 2012-04-09 13:57:42.583 Remote debug message: Agent forwarding disabled.
. 2012-04-09 13:57:42.947 Remote debug message: X11 forwarding disabled.
. 2012-04-09 13:57:42.947 Remote debug message: Forced command: /home/sshacs/acssshsink acetrax_test
. 2012-04-09 13:57:42.947 Access granted
. 2012-04-09 13:57:43.115 Opened channel for session
. 2012-04-09 13:57:43.508 Started a shell/command
. 2012-04-09 13:57:43.508 --------------------------------------------------------------------------
. 2012-04-09 13:57:43.508 Using SFTP protocol.
. 2012-04-09 13:57:43.508 Doing startup conversation with host.
> 2012-04-09 13:57:43.509 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2012-04-09 13:57:43.893 Type: SSH_FXP_VERSION, Size: 38, Number: -1
. 2012-04-09 13:57:43.893 SFTP version 3 negotiated.
Unsuccessful
! 2012-04-09 13:58:22.964 Authenticating with public key "rsa-key-20120217"
. 2012-04-09 13:58:22.996 Sent public key signature
. 2012-04-09 13:58:23.173 Remote debug message: Agent forwarding disabled.
. 2012-04-09 13:58:23.548 Remote debug message: X11 forwarding disabled.
. 2012-04-09 13:58:23.548 Remote debug message: Forced command: /home/sshacs/acssshsink acetrax_test
. 2012-04-09 13:58:23.548 Access granted
. 2012-04-09 13:58:23.721 Opened channel for session
. 2012-04-09 13:58:24.114 Started a shell/command
. 2012-04-09 13:58:24.124 --------------------------------------------------------------------------
. 2012-04-09 13:58:24.124 Using SFTP protocol.
. 2012-04-09 13:58:24.124 Doing startup conversation with host.
> 2012-04-09 13:58:24.128 Type: SSH_FXP_INIT, Size: 5, Number: -1
. 2012-04-09 13:58:25.111 Server sent command exit status 0
As my sessions are ASync - there is no difference in the settings done through the implementation
Should i be setting another property?
This SSH_FXP_VERSION is not authenticated properly. Should something be updated on my local machine?
Please suggest
c10c
logs
This is the logs i have. Any idea where i should look for the server logs?
I had set the WINSCP client log path but no server log path was set? Are they created automatically?
Re: logs
Server log has nothing to do with WinSCP. Every SSH server is different. So I cannot help here.
c10c
thanks
ahh, i get what you meant. you wanted me to check the server which i am connecting for their logs.. there is no problem from WINSCP side is what you meant
Re: thanks
Correct.
